beginningjockey's 360 to 318 swap
Old Mar 29, 2013 | 07:11 PM
aofarrell2's Avatar
aofarrell2
Default beginningjockey's 360 to 318 swap
So now I've finally settled on the plan for the RAM. I've got a 318 engine I'm getting to replace the 360 in the RAM. It's a 318 Magnum with Edelbrock intake and Edelbrock 4-barrel carb. It's got 100K on it, so not too bad! Complete engine I get for $500.
So I'm gonna post pics etc. here of the engine pulling process, and also on converting the 2nd gen chassis to a carb instead of EFI.
The PCM will still be in control of cruise, gauges, and for now the regulator (I'll change that down the road).
I'm swapping my 360 flywheel for his 318 flywheel since he needs a 360 flywheel and I need a 318 flywheel.
I will not be reusing the EFI fuel pump. Instead I will be running a new fuel line with a inline fuel pump to match the carb.
I also will be replacing motor mounts at the same time as insurance against their failure .
So at the present I am getting my shop cleaned so I have enough room for all of this.
More later. Oh, since
I will be sure to get pics for y'all .
Old Mar 29, 2013 | 07:15 PM
crazzywolfie's Avatar
crazzywolfie
just drop the fuel injected intake on the 318 and call it a day.
Old Mar 29, 2013 | 08:14 PM
aofarrell2's Avatar
aofarrell2
If I did that, then I'd have to pay $175 to get my PCM refurbished, plus $365 in custom tuning, not to mention all the other parts I'd need to swap intakes.
For now, it goes in carb'd. If I decide I want EFI again later, it won't be altogether that hard to switch back again, because I'll have the EFI stuff still. I'm hoping to stroke the 360 later if money and time allow. A carb'd engine is at least better than no engine lol.
Besides, why do all the big name magazines use a carburetor on their project big-power Magnum engines? Most I've ever seen used a carb, and those that didn't always used a aftermarket EFI setup.
Old Mar 29, 2013 | 08:41 PM
crazzywolfie
probably because the cars came from the factory carbed and it is cheaper to stick a carb on a engine that is going into something that was already carbed. you would be looking at at least $200 for the ignition system for a carbed engine plus $100 for new fuel pump. then there are many other things that may be getting overlooked. plus sticking a Fuel injection setup in a old car get expensive quick. you are usually looking at $2000+
Old Mar 29, 2013 | 08:42 PM
stewie01's Avatar
stewie01
Just buy the diesel you've been looking at and sell the 1500
Old Mar 29, 2013 | 09:29 PM
aofarrell2's Avatar
aofarrell2
I think you are misunderstanding. I'm not converting a 318 magnum I'm buying to carb, it's already converted for 20K mi. and running good. I'm just retrofiting a few things in our truck to make the carb setup work.
Also I was referring to a Magnum engine in the perf magazines, that were EFI before they grabbed them for a project.
http://www.hotrod.com/techarticles/e...e/viewall.html
I'm gonna get this one running
aofarrell2's Avatar
aofarrell2
Oh and it comes with all the ignition parts AND the fuel pump
Old Mar 29, 2013 | 09:37 PM
stewie01's Avatar
stewie01
Good plan, you'll get more for it in (good) running condition
Old Mar 29, 2013 | 10:33 PM
aofarrell2's Avatar
aofarrell2
I've got a couple people who want it already LOL... I won't name the price I quoted them for it though as it might cause some reprecussions lol... so if you wanna know PM me.
Old Mar 30, 2013 | 05:21 PM
snowboundrmk's Avatar
snowboundrmk
I can't wait to see how this works out. I plan on replacing my 318 with a mildly built 360 and convert the truck over to a carb since I have no way of tuning the obi-1 and it's cool and has less parts.
