Opinion on modds- Give suggestions/what not to do!
Old Mar 31, 2013 | 01:34 PM
dogbosser14's Avatar
dogbosser14
Any brand would you suggest buyin?
Old Mar 31, 2013 | 01:35 PM
merc225hp's Avatar
merc225hp
Originally Posted by dogbosser14
What do you mean by a dry/wet comp test? Something I would have to take in to do or no?
That depends on if you have or are willing to buy the tool for the job, you can buy a basic comp tester for say around $30 and up. Then it's a case of reading up on how to do the test right, you should be able to handle this as long as you can remove spark-plugs and wires. A comp test will give you a psi reading for each cyld the number relates to the cond of the motor. A good motor will have a number from say 140-165 psi dry test. A bad motor will have numbers in the 0-90 psi range. Min spec number by the book is 100psi. This is basic info and there is much more to it, best is to do a search on comp testing and read up on it. Dry test no oil, wet test you add a teaspoon of oil to the cyld before you test.
Old Mar 31, 2013 | 01:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Download a manual from the FAQ/DIY section. And get a Haynes too.
Old Mar 31, 2013 | 01:54 PM
merc225hp's Avatar
merc225hp
^^^ Are the fsm downloads working now?
Old Mar 31, 2013 | 02:55 PM
gdstock's Avatar
gdstock
01 FSM was last week, but 95 was not as of yesterday I read....
Old Mar 31, 2013 | 03:04 PM
zman17's Avatar
zman17
I thought DHV fixed them with help from crazywolf, I think.
Old Mar 31, 2013 | 03:06 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
A few ideas.
Old Mar 31, 2013 | 03:10 PM
zman17's Avatar
zman17
They are working for me.
Oh, and the only thing that will really help is the Fuzzy Dice.
Old Mar 31, 2013 | 03:27 PM
merc225hp's Avatar
merc225hp
Fuzzy dice are a good mod but if you add Dingle ***** to the fuzzy dice it adds some much more, plus the steering wheel cover man oh man look out.
Old Mar 31, 2013 | 03:46 PM
zman17's Avatar
zman17
Thanks, but I think I'll stay with the FD. Even if I'm losing some bottom end without the SW cover and dingle's. LOL
