Tire questions
Old Apr 24, 2013 | 08:23 AM
xcentrik05's Avatar
xcentrik05
Z rawk is right, 01 ORE's DID have 275-70/17's.
The build sheet will give the stock tire size it would have had BEFORE the ORE package was added, it won't give that size included in the package.
Ahh! i see i didn't expect that lol. So what's the tire size on the inside door? It shows tire pressure for 245/75/16?
Old Apr 24, 2013 | 10:04 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Never have figured that out myself. I think that's the BASE, BASE tire. lol
Why they have that there I have no idea.
But if you get LT 285's, run 45/40 front and rear. That's what I run, and it rides nice.
Old Apr 24, 2013 | 10:46 AM
gdstock's Avatar
gdstock
Larger tire = larger diameter. Speed counts axle revolutions to determine speed. With a larger tire, you cover more distance per revolution, so, speedo reads slower than what you are actually going.
Going to larger tires, even with a tuner, WILL reduce fuel economy for your driving style. It will be slightly better on the freeway.... but, I don't think you do enough of that to offset the around town losses. Re-gearing would help, but, it would take forever for the boost in fuel economy to offset the cost. You should already have 4.10 gears though, so, you may not see too much of a difference.
One thing to keep in mind when calculating mileage. If tires are oversized, do NOT use odometer to calculate mileage with or it will be calculated incorrectly. It will look worse thn it is.
Old Apr 24, 2013 | 10:52 AM
dodge dude94
You divide the mileage by the old tire size, in inches, then multiply that number times the new tire size.
Boom, fixed.
Old Apr 24, 2013 | 12:57 PM
xcentrik05's Avatar
xcentrik05
Boom, fixed.
What about the odometer? will it be off as well?
Old Apr 24, 2013 | 01:01 PM
dodge dude94
Yeah, but only slightly since you already have an ORE.
