Planning for 360 build
Old Jun 1, 2013 | 05:14 PM
Ham Bone's Avatar
Ham Bone
Default Planning for 360 build
Alright, gotta another ride so that means the truck can have some significant downtime. I plan on pulling the 360 out in the fall/winter months to rebuild with some performance parts
I'd like to collect the parts over the summer as much as possible so it won't break the bank as bad lol.
I have my own ideas but I'm a complete noob at this. First time planning a build and stuff. the wrenching won't be a problem but I know for a successful build everything has to work together.
General idea for the build- want to beef the power up and keep it down low. It's still a truck the torque should be down low
Initial things to do
Rings? I've got 210,000 miles on it. Compression is around 150 across the board but I figure why not. Don't know what kind though. Can you replace rings without having to bore?
Cylnder Heads- Clearwater Odessa seems to be the best. I first wanted the ones similar to the Hughes iron rams with stock size valves but better castings with better flow. I don't see them on eBay anymore however. Would the monster EQ heads with larger valves work with right intake/cam?
Cam- no clue on this one, don't want a screamer
Rockers- always wanted 1.7 Harland sharp but I know that can cause some problems if you don't plan right
Intake- maybe an M1 but As I understand that's for higher rpm motors. Considered a Hughes but then read how ghetto it actually was. Probably gonna keep the kegger
Lifters- what kind and from where?
Bottom end- guess it depends on what it looks like when I open everything up. No reason to believe its not fine. Maybe crank bearings?
Sct tuner and wideband O2
Well that's all I can think of at the moment. I'm open to all suggestions. I'm a beginner with this engine building stuff so I need all the advice I can get
Aren't the sct tuners being discontinued?
Old Jun 1, 2013 | 08:29 PM
dlyter09's Avatar
dlyter09
Question is.. What is your budget? What kind of power numbers do you want?
Old Jun 1, 2013 | 08:44 PM
stewie01's Avatar
stewie01
And yes the X2 9550? is being discontinued by SCT. Sean at Hemifever had some stock left, they are going to X3, could be a couple of months before it's ready and it will be another $100-$150...
Old Jun 1, 2013 | 11:08 PM
Ham Bone's Avatar
Ham Bone
Not real sure on the budget yet. Just taking in all ideas and trying to get a sense of direction
Old Jun 2, 2013 | 12:26 AM
dlyter09's Avatar
dlyter09
Stroker for the win!!
Old Jun 2, 2013 | 08:34 AM
stewie01's Avatar
stewie01
Take a look at Rednecks build thread, I think he spent over $4k on the motor all together. But it would give you an idea for a good low end grunt motor...
Old Jun 2, 2013 | 09:14 AM
Ham Bone's Avatar
Ham Bone
I have, I should do that again haha
Old Jun 2, 2013 | 01:11 PM
merc225hp's Avatar
merc225hp
Yep have a look at his thread. He never touched the short block so add about $2000 more to that price tag.
Old Jun 2, 2013 | 03:20 PM
Ham Bone's Avatar
Ham Bone
What makes the short block 2000
Old Jun 2, 2013 | 03:49 PM
merc225hp's Avatar
merc225hp
Pistons, rods, crank, bearings, balancing the rotating assy, machine work, and so on. A small kit for say a 365cid is around $1200+ with those parts and balancing, but you need to add the cost of machine work as well, so $2000 is on the low end of things. The block would need to be specd out to see if you can just re-ring it, if you are going to do this do it right don't half A** anything, build it the right way and it will out last the rest of the truck, and make some good numbers at the same time.
