5.9 efi with AC pump removed.
Old Jun 23, 2013 | 10:29 PM
  #21
Wh1t3NuKle's Avatar
Wh1t3NuKle
Problem with using the A/C compressor as an on board air compressor is the lack of oiling. The A/C compressor gets it's oil from the refrigerant.
You got that right.
@Preston -- You threw money away with those Yorks. :shrug:
Old Jun 24, 2013 | 09:29 AM
  #22
I have seen folks use the A/C compressors that don't have their own oil capability. Trick is to run a 'oil bath' intake filter, so some oil is drawn in with the air. Need to make sure the reservoir doesn't run empty though.
Old Jun 26, 2013 | 01:41 AM
  #23
snowboundrmk's Avatar
snowboundrmk
Do non ac trucks have a different accesory drive bracket, is that why non ac belts don't work on ac removed trucks?
Old Jun 27, 2013 | 01:44 AM
  #24
Hahns5.2's Avatar
Hahns5.2
Yes, as already explained earlier in the thread, the idler pulley is in a different spot. I also posted details on how to get the correct belt if you want to remove the AC.
