snowboundrmk's 360 build
Old Jul 4, 2014 | 01:05 PM
  #231
With headers, they probably aren't. With the cast iron manifolds, it isn't necessarily WHILE the engine is running that is the issue, its after you shut it down, and there is no airflow thru there, cast iron makes an awesome heat sink.
Old Jul 4, 2014 | 01:56 PM
  #232
Wh1t3NuKle's Avatar
Wh1t3NuKle
I don't think it's a derail.
The shield is not an air deflector. It's purpose is interrupting radiant heat. Emissivity is the key property here among other things comparing shiney headers to rough/dark factory manifolds. Shiney is higher value, higher radiant heat...
Around town driving is where the influence is greater, which would be associated with laminar characteristics.
This is why I think they are needed even more so with shiney headers.
Edit --
Correction: I always get that reversed on emissivity level. Shiney is opposite.
Are those actual temp measurements you took by the way?
Originally Posted by Spillage
Not to derail the thread, but could expand on why?
I've considered removing mine (torn and rattling) since going to headers.
With the stock manifold I can see the need, but headers are further away from the mount, and the max temp I've seen on top of the shield is less than 140°F, even after a 70mph run on 90°F+ day, and then an idle heat soak.
Regularly it is ~124°F.
Radiant heat from the block has to be at least that... IAT is ~130°F.
With headers, I don't think they're needed.
Old Jul 4, 2014 | 04:02 PM
  #233
Spillage's Avatar
Spillage
Originally Posted by Wh1t3NuKle
...Are those actual temp measurements you took by the way?
Yes, actual temps.
I have an engine oil temp gauge installed that the sensor doesn't have a home yet, so the sensor I strapped to the top of the heat shield to see what the temp was.
I've also shot it with an infrared heat gun after pulling up in my drive, getting the same numbers.
~45min on the hwy, ~7min on surface streets w/lights, then pull up in the driveway and idle... 1min sitting in the drive was the highest temp.
My contention was the shield is to stop radiant heat from the close proximity of the stock cast manifold... the header tube is further away... it should also be remembered that heat rises so less heat is going to radiate down, most of it will go up.
Old Jul 5, 2014 | 07:23 PM
  #234
snowboundrmk's Avatar
snowboundrmk
I can't get one of the converter/flexplate bolts to line up. I tried every way, but this one never lines up. The pattern must have changed over the years between my old 95 5.2 and the new 99 5.9. Is it okay to grind the hole so it lines up?
Old Jul 5, 2014 | 07:57 PM
  #235
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Snow, you can't grind those, everything has to be balanced. Are you using the 5.9 or the 5.2 flexplate? It has to be the 5.9 flexplate because they are balanced differently.
Old Jul 5, 2014 | 08:09 PM
  #236
snowboundrmk
It's a 5.9 flexplate. There is a weight on it. I was hoping that little bit I grind off wouldn't make a difference.
Old Jul 5, 2014 | 08:29 PM
  #237
Is that the original 5.2 torque converter? If so, you are prolly gonna have to replace it. Grinding it so the bolt will fit will ensure that things are NOT completely balanced, and after the money you have invested in this project, that would be a bad thing to do....
Also, the way they balance the 5.9 changed in 96. Went from a weight on the flex converter, to the weight on the flex plate. So, you have an early model truck, with a later model flex plate, and evidently, the wrong converter for it to match up to.
Old Jul 5, 2014 | 10:15 PM
  #238
snowboundrmk
Maybe i'll just put it in cross threaded haha. Nv4500 swap shouldn't be too long!
Old Jul 5, 2014 | 10:17 PM
  #239
stewie01's Avatar
stewie01
Won't matter if you tear the motor apart
Old Jul 6, 2014 | 04:56 PM
  #240
snowboundrmk
So I should use my old 95 5.2 flex plate and buy a 95 5.9 torque converter? And will a $80 torque converter from oreily's be ok?
