installing cab clearance lights
Old Oct 22, 2013 | 01:45 PM
cntry_prernnr's Avatar
cntry_prernnr
Default installing cab clearance lights
has any one installed cab clearance lights on a 1500 slt that didnt have them to begin with? im buying go recon smoked led's.
http://www.gorecon.com/product.php?p...ts-Dodge-03-14
Old Oct 22, 2013 | 01:58 PM
Do you have a specific question or just want to know if anyone has them that didn't have them before?
Old Oct 22, 2013 | 02:16 PM
cntry_prernnr
just wanted to know if any one has done the install and how they did it. basically what ever info i can get before i start installing
Old Oct 22, 2013 | 02:17 PM
Jimythefan's Avatar
Jimythefan
Search "cab lights" and you'll find several threads on how to do it. Easy enough to do, just takes time to get it right.
Old Oct 22, 2013 | 03:45 PM
redneck_ram's Avatar
redneck_ram
I installed factory cab loghts on my truck. They havent had any leaks yet and loom great. 2nd gens make it easy cause there are access holes already in the interior roof.
Old Oct 22, 2013 | 03:59 PM
ChillyPhil's Avatar
ChillyPhil
I plan on ordering the same thing sometime. I just don't want my headliner to sag after the work is done.
Old Oct 22, 2013 | 04:08 PM
Jimythefan's Avatar
Jimythefan
Headliner won't sag unless it's having issues already. The material is attached to a hardboard type material and is stiff enough to be removed and reinstalled with out coming apart. To be on the safe side, it's best to have 2 people when doing this.
Old Oct 23, 2013 | 12:17 PM
Ramman18's Avatar
Ramman18
I installed cab lights last fall. Did not remove headliner, just lowered it a bit. I used the Pacer smoke lens kit and wired it up my own harness. I read too many bad reviews on Recon and they don't look like factory. Pacer has the same shape and lens as factory. Only problem I had was I ordered LED and they came with LED bulbs, not wired into the light assy. Turns out, this is better. If a bulb goes out, it can be replaced. If the assy died, would have to re-wire a whole new cab light. I also ditched the LED because they only shown straight ahead and were kind of yellow. They also sent me amber incandescent bulbs which I used and are brighter and actually orange. I tied it into the running lamps behind the light switch.
There are many write-ups on cab lights around the webz. Here's my favorite:
http://www.phildorsett.com/clearancelights.html
Old Oct 23, 2013 | 12:36 PM
FireDodge's Avatar
FireDodge
I installed mine last spring-ish. Just lowered about half of the headliner and drilled away!
Old Oct 24, 2013 | 01:50 AM
cntry_prernnr
thank you so much!
