Headlights, 1 bright, 1 dim no matter what
Old Nov 17, 2014 | 04:09 PM
MichaelCashwell's Avatar
MichaelCashwell
Default Headlights, 1 bright, 1 dim no matter what
I had my driver side bright go out, thought it was the bulb so went to change them. found out it is the connector, it had burnt. Fixed that, now with my new bulbs, on dim my driver is bright and passenger is dim, on bright they switch, driver dim and passenger bright. Also when on dim the bright indicator in dimly lit..... pulled the fuses one at a time noticed that with either fuse in both headlight still are lit.... I have checked the Pur/Wh wire in the steering column, and been pulling the wires out checking for any fraying or signs of shorts with no luck... any ideas?
Old Nov 17, 2014 | 06:19 PM
UnregisteredUser's Avatar
UnregisteredUser
I'd start by looking for miswires in that repair job.
Old Nov 17, 2014 | 06:26 PM
MichaelCashwell
it was a simple snip and replace terminal fix, no rewiring, thanks!
Old Nov 17, 2014 | 06:44 PM
Bad ground somewhere.
Old Nov 17, 2014 | 07:03 PM
MichaelCashwell
would that still cause the bright to come on when it should be dim?
Old Nov 17, 2014 | 07:27 PM
UnregisteredUser
Got the correct replacement bulb? A relatively common mistake is to install 9007's where 9004's belong, or vice versa. They're connected differently internally and so are essentially a hidden miswire, and will cause the symptoms you've got. Either way, a dimly lit high beam indicator is a symptom of one or the other fault.
PS: Get the model year of your truck into your profile and it'll make it easier for folks to help with these kinds of things.
Old Nov 17, 2014 | 07:44 PM
MichaelCashwell
i'll look into the bulbs, make sure I got the right ones, and thanks for the reminder on the year, I over looked that.
Old Nov 17, 2014 | 07:53 PM
MichaelCashwell
i've put in 9007, it seems as if they should have been 9004........ its the little things, I'll get that changed and see if it works right.
Old Nov 17, 2014 | 10:42 PM
UnregisteredUser
Yep, they're supposed to be 9004. It's nice that it's an easy fix.
Old Nov 18, 2014 | 07:35 AM
Good job, sir.
