how strong is a stock 9.25 rear end
Old May 26, 2015 | 08:06 PM
LSX RAM's Avatar
LSX RAM
Default how strong is a stock 9.25 rear end
My 1500 2wd pickup has a 9.25 rear end. How much HP can it take before it snaps an axle or tears up the gears?
Old May 26, 2015 | 10:56 PM
Ham Bone's Avatar
Ham Bone
Well it's a c clip axle....
Old May 27, 2015 | 12:04 PM
Moparite's Avatar
Moparite
Yea the c clip is the weak link. Over all it's a strong rear(depending how it's used). Gears can go in any axle so i wouldn't blame the axle itself. There is a reason why it's been in use since the early 70's!
Old May 27, 2015 | 01:13 PM
FireDodge's Avatar
FireDodge
Not really horsepower related, but a guy in my area ran 37's, 4.10's and a factory lsd and wheeled the crud out of it with no problems.
My factory spider gears blew while trying to do a burnout within the first year I owned it. And that was on a stock motor, 3.55's, and 33's.
Old May 27, 2015 | 09:22 PM
LSX RAM's Avatar
LSX RAM
OK that gives me an idea. I need to put a posi carrier in it, C-clip eliminator? and 3.90 gears. Shooting for around 400 rwhp.
Old May 28, 2015 | 08:50 AM
Moparite's Avatar
Moparite
I don't think a C-clip eliminator is available for the 9.25, Only gm stuff.
http://www.eaton.com/Eaton/ProductsS...trac/index.htm
Old May 28, 2015 | 09:01 AM
Ham Bone's Avatar
Ham Bone
Where's the guy with track only Dakota with a 408. wonder what rear he has.
Old May 28, 2015 | 08:39 PM
LSX RAM's Avatar
LSX RAM
Ok thanks man
Old Jan 18, 2024 | 08:19 PM
Ram Rebel's Avatar
Ram Rebel
you can get a oem limited slip differential and bearings from Mancini Racing and you will not need any other parts. And the long tube with a socket that goes through the axle tubes to adjust the bearing torque.
Plus the newer 5.7 rams have 395 hp stock.
I replaced the open diff in my 17 ram with a limited slip.
Old Jan 18, 2024 | 08:23 PM
9 year old thread..... I would like to think he has had this back together for quite some time.
