The Official 2nd Gen Ram OT Thread
Old Nov 21, 2018 | 06:16 PM
  #631
Gary-L's Avatar
Gary-L
Veteran: Navy
Another must listen-to for the younger folk (anyone under 45) for Thanksgiving.
Old Dec 15, 2019 | 07:28 PM
  #632
Xombi's Avatar
Xombi
Default What I did today
Today I tore down a working 2002 46re I bought to replace my badly fragged 46re 2001. The old 46re was metal to metal in both the front and rear bands and drums, and the magnet and speed sensor were coated. That much metal must have played havoc with the piston bores and valve body.
New trans everything but the od and valve body taken apart and cleaned up. Clutches worn but having meat, front band on the edge of dying and rear band like new.
I intend to bypass radiator and use an auxiliary cooler. Flush lines.
Is the SKTFOD shift kit overkill for a vehicle that will see occasional tow duty? When used with a Dodge A727 A518 46RE A618 47RE Transmission Front Band Apply Super Servo (81032)?
Which is the recommended front band? Some say heavy dutu others kevlar, others still carbon It only a 360 v8 that will see occasional towing. My hard parts are all very good so I have the same question on frictions.
Have not yet figured out how to retrofit 3 pin trans switch for 5 pin. in later case. The sonnax directions are are lacking.
Old Dec 15, 2019 | 07:31 PM
  #633
Alto Red Eagle clutches.
Old Dec 15, 2019 | 07:36 PM
  #634
Xombi's Avatar
Xombi
Default Alto red eagle clutches
Same for the bands? Are the valve body and pressure upgrades a reasonable bet?
Old Dec 15, 2019 | 07:43 PM
  #635
Yeah, if they offer them, use their bands as well.
Shift kit looks to be designed for diesel? Though the 46 never came behind a diesel.
MonteC (our one-time resident trans guru) recommend the Sonnax Sure cure kit. It addresses a LOT of issues with the trans. Including charging the t/c in park.
Old Dec 15, 2019 | 08:06 PM
  #636
Xombi's Avatar
Xombi
Default Sonnax shift kit
The Sonnax kit needs $200 in jigs and fixtures.
Old Dec 15, 2019 | 08:34 PM
  #637
I think they also offer a 'qwik kit', or some such. You also don't need to use all of it.
Old Dec 25, 2019 | 10:44 AM
  #638
2bit's Avatar
2bit
Merry Christmas
Old Apr 28, 2021 | 11:19 AM
  #639
horace's Avatar
horace
I've been very fortunate no trans or fuel pump on the 97 w/ 217,00 but can't seem to get the door not to sag, always seem to have cd player troubles. NO I'm not putting a whiz bang radio!! My 97 w/ 270,000 starting leaking trans fluid badly one day, did the trans. Have had RUSTY brake lines, I suppose the box or cab mounts are rotted out as well.
Old Jun 4, 2021 | 04:21 PM
  #640
adukart's Avatar
adukart
If anyone has ever wondered what living in ND is like, we had snow falling 8 days ago, today we broke the record high temperature of 95 by 3 degrees before noon. It is now 103 out and climbing.
