Aftermarket Sport Headlights
Old Jan 5, 2016 | 06:31 PM
jsmith1969's Avatar
jsmith1969
Stock housings, good bulbs, properly aimed, and the relay harness...... DRAMATICALLY improves the stock lites. Usually cheaper than aftermarket housings too...
By relay harness are you talking about the one from LMC that is supposed to make them better? I've been on the fence about if it's worth it.
Old Jan 5, 2016 | 10:30 PM
Pretty much, but, it is designed for the non-sport trucks. You would be further ahead just buying some wire, connectors, and relays, and building your own harness..... Advantage being, you can use larger wire than the LMC harness.... theirs is better than stock, but, wire size is still questionable.
Old Jan 6, 2016 | 09:15 AM
jsmith1969's Avatar
jsmith1969
Ok cool, found the writeup in DIY section. Think I'm going to do this soon.
Old Jan 6, 2016 | 01:14 PM
Maximillio's Avatar
Maximillio
Could you link us to that write up?!
Old Jan 23, 2016 | 05:29 PM
UnregisteredUser's Avatar
UnregisteredUser
Not trying to be contrary but doing it anyway: AWG12 being 1.59 ohms per thousand feet, ten feet of it is 0.00159 ohms; throw 20A through that ten feet and the voltage drop is 0.0318V which is certainly negligible. Even if you could get zero voltage drop somehow it wouldn't increase measurable light output above that of the LMC kit, and with the voltage regulation being no more precise than it is on our trucks you couldn't get reliable measurements anyway.
The time and money I didn't spend on DIY'ing got spent on marijuana instead. In my world that's a good outcome.
Old Jan 23, 2016 | 07:02 PM
LOLOL.
Ok, I'll give ya that one.
Old Jan 23, 2016 | 07:55 PM
UnregisteredUser
There's my one for the year.
Old Jan 23, 2016 | 09:09 PM
Black02CrCb's Avatar
Black02CrCb
/\ lol
