New reliable truck
hmm so I will look for just 3 inch springs maybe then.. any good recommendations? if I do this should I add a leaf to the rear to sit back level or add a 1 inch taller block? not really up to speed on lifting trucks.. only did a level on my other brand truck and its 2wd so it was really easy.
There is already a block in the back.... I am just not a fan there. Blocks give the axle more leverage on the spring, so, axle-wrap is a real concern. I would be far more tempted to go with an add-a-leaf.
Top Guns Customz will have everything you need. As for brands.... Stick with those you recognize, and read reviews of the products you are considering buying.
