The Replacement Truck.
Old Feb 13, 2017 | 04:41 PM
  #31
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Yes, sounds like it will keep you busy, but that work will pay you back in dividends.
Yes, i do know that the 2nd gen Rams did come with 2 different steering box ratios. 1:15 and 1:18. I think the 1500s and some 2500s came with the 1:15 boxes.
Old Feb 13, 2017 | 04:44 PM
  #32
Steering box in this one got replaced at some point in the past, I think they but the 1:18 in there, as it drives a LOT different than the 96.... I actually liked the 96 better in that respect, but, that one is pretty low on the priority list. (maybe, if the 96 doesn't sell, I'll yank the steering box, go thru it, and put it on the 98.......)
Any idea how to REMOVE window tint? I don't think it's factory, and it makes everything out the drivers window blurry.
Old Feb 13, 2017 | 04:47 PM
  #33
44dakota's Avatar
44dakota
looks good hey you , im sure you can fix the rust, whats the HP and toque rating on those v10s?/
Old Feb 13, 2017 | 04:51 PM
  #34
I am going to talk to my boss at work, in a previous life, he was a paint and body man. See if he is willing to help me out.
310hp/450tq I think. A LOT more power than the tired 360 in the 96.
Old Feb 13, 2017 | 04:53 PM
  #35
Jimythefan's Avatar
Jimythefan
The lockup on mine hunted around quite a bit too. I just put it down the 3.55s and the death flash. Hemifever's tuner put an end to that.
Old Feb 13, 2017 | 05:02 PM
  #36
On mine, even at steady-state cruise, ANY even very tiny change in throttle position will cause the tcc to unlock/lock.... It's REALLY annoying.
Old Feb 13, 2017 | 05:04 PM
  #37
1997JollyGreenGiant
I removed the tint on my truck. Was super dark aftermarket tint from previous owner. Was easy to remove, just used a paint scraper / razor blade to lift the tint on one corner, and i slowly pulled the tint off. Mine came off in 1 piece.
Old Feb 13, 2017 | 05:46 PM
  #38
That'd be way too easy.....
Old Feb 13, 2017 | 06:17 PM
  #39
Moparite's Avatar
Moparite
Usually the tint will come off but the adhesive stays. That's the hard part to get off. Just use windex and let it soak in a while before scraping it off with a razor blade. It's a real pita!
Old Feb 13, 2017 | 07:40 PM
  #40
Good to know. Thanks. I have some Goo Gone at work, wonder if that would take it off.....
