1995 ram 1500 5.9 4x4
Old Sep 29, 2017 | 10:53 PM
gramsey's Avatar
gramsey
Default 1995 ram 1500 5.9 4x4
will not start when cold outside have to leave key on then in 5 to 15 minutes starts to make a clicking sound at the relay box when clicking stops power is sent to fuel pump truck starts and runs fine any ideas checked relays they are all in spec
Old Sep 30, 2017 | 08:06 AM
That's bizarre. What AREN'T you getting when it won't start? Will it crank? Do you get spark?
Old Sep 30, 2017 | 08:31 AM
Moparite's Avatar
Moparite
[QUOTE checked relays they are all in spec ][/QUOTE]
Does this mean you replaced it(fuel pump relay) with known good one?
Time to do some investigating, Either the pcm is not getting power from the ignition switch or the pcm is bad or has a wiring (bad connection) issue. The fuel pump should prime as soon as you turn the key to on.
Old Sep 21, 2019 | 01:32 PM
BamBam1955's Avatar
BamBam1955
I had the same problem and it was the computer they're about $260 on i believe its called best computers rebuilt don't make new ones anymore
Old Sep 21, 2019 | 03:54 PM
Two year old thread. I would hope he got if fixed by now.
