V10, Think it's Worth it?
Old Mar 2, 2018 | 06:51 AM
smoky614's Avatar
smoky614
Originally Posted by Ramman18
The 5.2 and 5.9 are so close in power (15hp) that either one will pull/haul whatever you like. Might consider beefing up a 5.9 to haul better like gears, bags in the rear, etc. But if you feel the 5.2 isn't up to the task, neither will the 5.9.
Right, right. I know i said 5.2, but it's not really the motor I had the issue with. Shes yet to let me down, even had to chain tow a 1ton ford diesel with her(still haven't let my buddy live that one down!) Took it like a champ, didnt even hit 4k rpms(milkin it a bit)! Its the 1/2 ton i have to step up. Smacked them bump stops more then once!
Old Mar 2, 2018 | 09:06 AM
Originally Posted by smoky614
yeah, from all the googling ive been doin it seems like the clear choice between the two and if it wasnt for the frame id probably go with it! How many miles have you gotten it upto? I managed to get my 318 from 150k to320k with just a water pump, alt replacement and radiator + a few hoses and tune ups(engine wise anyways!),still runnin like a champ! Id expect the same for the 360(almost identical if im not mistaking). Are the V10's typically long lived motors?
I have 135K on mine at the moment. (one of the reasons I bought it......) But, others I looked at were north of 250K, and a few over 300K...... still original engine and trans..... (which was amazing.) Unfortunately, the high-mileage trucks were rotted out really bad.... (salt on the roads around here.....)
Old Mar 2, 2018 | 11:33 AM
Ramman18's Avatar
Ramman18
Then your question really should be: 2500 or 3500? And 3.55 or 4.10?
If your 5.2 has done well for you, look for a clean 2500 with the 5.9 (cheaper and more plentiful than V10 or CTD), do the necessary engine/driveline repairs including steering, add an overload spring or bags and get R done! Even better, find a 5spd!
Old Mar 2, 2018 | 08:16 PM
And there is a fair bit more aftermarket support the the 5.9 engine.... Though, not as much as I would like.
