Back again!
It needs a good seafoam treatment, full tune up with brass parts, and then run hard and put away wet.
And deathflash is what I've had since 2002 and I still have fought ping for years off and on. Tuning it will make it way way worse. There is no 'cure.'
Have a read:
http://dodgeram.org/tech/gas/Trouble/ping.htm
Have a read:
Have a read:
Have a read:
Issue seems to have been with the plenum. I put a hughes kit on it and the pinging has stopped.
I agree, run Seafoam in the next 2-4 tanks of gas. It usually helps after a 1/2 tank, but I think it takes longer than one tankful to clean everything up. It will actually clean carbon out of the combustion chamber.
I would do both the fuel treatment and vacuum one
