rear main seal
Old Mar 6, 2020 | 10:49 AM
YBT's Avatar
YBT
Default rear main seal
Hello guys I'm new on this forum. I have a Dodge ram 1500, 5.2L (Very well maintained). I recently changed the rear main seal and the oil leak still persist. I have read about off setting the seal, do you know if that will work better on preventing the oil leakage?
Old Mar 6, 2020 | 12:08 PM
Is there a groove in the crank where the seal rides? Did you lube the seal good before installing it? I haven't seen an offset seal for these engines, but, that doesn't mean it isn't out there.
Old Mar 6, 2020 | 01:09 PM
YBT's Avatar
YBT
the crank is in a pretty good condition. i did lube the seal.
like this video says, i know it is not a dodge engine, just wanted to find out if this tip will work on dodge engines.
Old Mar 6, 2020 | 01:25 PM
Ramman18's Avatar
Ramman18
Did my seal couple years ago and it leaks exactly the same ever since. I off-set it in the bearing as well. Once something leaks, it leaks forever in my experience.
Old Mar 6, 2020 | 03:10 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I always coated mine in RTV as Chrysler's instructions and never had one leak
Old Mar 7, 2020 | 07:54 AM
Moparite's Avatar
Moparite
You are supposed to put a little on the mating edges, And going around the outside is not going to hurt either. Then put a light coat of grease on the lips of the seal and the crank surface.
Old Mar 7, 2020 | 02:39 PM
MoparFanatic21
I always do it like that. I put a light coating all over it. A little grease and then go in like butter
