P1391
Old Apr 14, 2020 | 09:44 AM
Kaleb Dwyer's Avatar
Kaleb Dwyer
Default P1391
My 97 1500 5.9 runs good but is still throwing a P1391 code. I had the crank position sensor replaced by the dealership. I replaced the distributor too about a year ago. Runs good just annoying still having the code come up. Plugs and wires are about a year old. Tried a different pcm stil get the code. While looking underneath the truck I noticed a ground wire next to the crank sensor was burnt by the header not sure if it's related. Anybody have any ideas what it could be?
Old Apr 14, 2020 | 10:11 AM
Well, since you replaced everything else, it is most likely a wiring issue. Might just be a bad connection somewhere.
Old Apr 14, 2020 | 10:42 AM
Kaleb Dwyer
Do you think it could be something with the timing chain stretching or jumped after replacing cam and crank sensors? Has 125k miles not sure if could be bad already.
Old Apr 14, 2020 | 11:49 AM
Kaleb Dwyer
I have a clicking noise that you can only hear in gear not park wondering if it's the timing chain now......
Old Apr 14, 2020 | 01:19 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Use a mechanics stethoscope to see if the noise is coming from the timing cover
Old Apr 14, 2020 | 01:58 PM
Kaleb Dwyer
Wheres the best place to try and hear the timing chain? Underneath the truck or under the hood toward the middle of the motor?
Old Apr 14, 2020 | 05:32 PM
Probably underneath.....
Old Apr 14, 2020 | 07:05 PM
MoparFanatic21
I agree with HeyYou underneath right in front of the oil pan
