bad alternator??
Old Dec 17, 2021 | 09:43 AM
Originally Posted by PR1AWRet
A couple of weeks ago truck wouldn't start. Battery was dead. Threw in a new battery and it started. The next morning the new battery was dead (overhead map light switch). Jumped it, let it charge a few from the other car, then took the negative cable off and truck died. Onto a new alternator. Usually on older vehicles when the battery dies the alternator isn't too far behind or vice versa.
I'm not sure that's a valid test on a computer controlled engine....... If there is no connection to ground, the computer instantly stops working....
Old Dec 17, 2021 | 10:52 AM
aleekat's Avatar
aleekat
Bad Idea
Old Dec 17, 2021 | 09:08 PM
ol' grouch's Avatar
ol' grouch
Disconnecting the battery while running is a simple way to destroy ANY alternator equipped system. Not only will it freak a computer out, pre-computer cars from the early 1960's and up have alternators. Unlike generators, which you CAN disconnect, there are NO permanent magnets in an alternator. There IS a diode. It's a little bitty thing but critical to the alternator working. Unhooking the battery while running is like cross jumping a battery. It can blow that diode out right away. You now have no way to change the AC the alternator makes to the DC current it needs.
Old Dec 17, 2021 | 09:38 PM
aleekat's Avatar
aleekat
FINALLY. A professional who knows the systems. Thank You.
