DIY Exhaust Kits - Anybody Get One?
Old Nov 13, 2021 | 11:09 AM
Ramman18's Avatar
Ramman18
Default DIY Exhaust Kits - Anybody Get One?
I'm researching exhaust kits to complete the system after getting the Jegs Y-pipe and found these "complete" DIY kits on Ebay:
First Option -- I like the 50 Delta Flow since I ran one for about ten years but the pipes don't have the hangers welded on. Price $297:
2. Second Option -- This kit has the hangers on but doesn't come in Delta Flow 50, only Super 44 (louder) and it's cheaper at $235:
I'm torn between the two. Also concerned the pipes will clear the hitch in the back. The last kit I had was custom installed and had side exits. There is an option but it's over 300 and I can't see how the pipes would fit exactly from the pictures:
Thoughts? Anybody have one of these? At the moment, I'm running a cheapo glasspack and straight pipe off the Y-pipe dumped under the cab so it's pretty loud inside.
Old Nov 13, 2021 | 12:55 PM
Anyone in your area do custom pipe bending? The lack of cats might be a stumbling block.....
Old Nov 13, 2021 | 01:57 PM
Ramman18's Avatar
Ramman18
Huh? Cats? This is a bolt up system post intermediate pipe. Which I have. Besides, I'm a dog person.
I don't want to use a shop. Hence the DIY kits since I've done all my own exhaust work for over five years.
Old Nov 14, 2021 | 10:47 AM
Ramman18's Avatar
Ramman18
Glad I waited. After reviewing the posts very carefully I see the Performance Curve is the only option it turns out because the other two come with 3" inlet when I have 2.5" from the Y-pipe. Hopefully it will fit around the hitch. The other brands are meant to fit the 2-3/4" stock size which makes sense.
Old Nov 14, 2021 | 12:44 PM
I thought the jegs y-pipe was 3" outlet??
Old Nov 14, 2021 | 04:26 PM
Ramman18's Avatar
Ramman18
Nope, 2.5".
Old Nov 14, 2021 | 08:55 PM
Must be the pacesetter y-pipe is 3" then.
Old Nov 15, 2021 | 08:36 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Do you have a link to that Y pipe I have to buy one and was going to go with the Jegs because I thought it was 3" also
Old Nov 15, 2021 | 09:54 AM
Ramman18's Avatar
Ramman18
This the one?
https://www.summitracing.com/parts/psm-82-1183
Here's Jegs:
https://www.jegs.com/i/JEGS/555/31021/10002/-1
Old Nov 15, 2021 | 02:11 PM
That be the one.
