Tires and Rims
Old Jan 25, 2023 | 12:51 PM
UltraBlue342's Avatar
UltraBlue342
Default Tires and Rims
Hey, this is my first post. I've been lurking on the site for a while. If this is in the wrong spot lmk. I need help knowing if the rims and tires I want will fit properly. I've done a bunch of reading and the only thing I'm not sure on is the hub bore size.
Rims
https://www.tiresouth.com/wheel/8128...l/?finishID=12
Another Choice.
https://www.jegs.com/i/Black-Rock/26...88045/10002/-1
Tires (255/80r17)
https://simpletire.com/brands/falken...&userRegion=99
Old Jan 25, 2023 | 01:04 PM
What are you driving? The first set of rims are 8 lug, second are 5 lug.....
Old Jan 25, 2023 | 01:06 PM
UltraBlue342
1999 Dodge Ram 2500 4x4
The second link is just a representative picture. The description shows they're 8x6.5
Old Jan 25, 2023 | 01:18 PM
Ok. Missed that.
Yep, you need the 8 lug. The zero offset fellers should fit pretty will, and be close to factory backspacing. (first link) The dodge rims, I do believe, are lug-centric. (the lug nuts keep them centered properly) so as long as they will fit over the hub, yer good. Going with 17's is a good choice, as there are a larger tire selection available for 17's, and they are cheaper.
If you have 3.55 gears in your differentials, you will definitely notice the larger tires though.
Old Jan 25, 2023 | 01:21 PM
UltraBlue342
Cool thanks. I'm getting a tune up and new exhaust at the same time so hopefully it offsets and I won't notice much lol.
Old Jan 25, 2023 | 07:58 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
Rims
Another Choice.
Tires (255/80r17)
Those tires are 33" tall. If you have 3.55 gears, you WILL notice a loss of get-up-and-go when taking off from a stoplight. You will also need to have the speedometer calibrated to accommodate for the larger tires. With a 1999 truck, I believe some tuners can adjust the PCM to make the speedometer read correctly.
Old Jan 26, 2023 | 03:17 PM
UltraBlue342
Yeah I'm aware of all that. It's worth it to me tho, I can't handle the training wheels anymore.
