DEFROST AND AC PROBLEM
Old Mar 29, 2007 | 11:01 PM
N10SRAM's Avatar
N10SRAM
Default DEFROST AND AC PROBLEM
I have a 98 ram with a 318 in it. I havea problem with the dash vents switching to the defrost vents by themselves. A dealer told me I had a intake leak, but I think I would be showing some sort of code if this was true. Has any oneelse out there had this problem? If so what is the fix for it.
I am new here so if this a old question I am sorry but I have not been able to get any answers.
Thanks,
Matt
Old Mar 29, 2007 | 11:34 PM
2001mustang_gt's Avatar
2001mustang_gt
Default RE: DEFROST AND AC PROBLEM
you do have a vacum leak on your intake that is the cause of your problems..it should be on your pass side just under the throttle cable
Old Mar 30, 2007 | 12:09 AM
ram51's Avatar
ram51
I had it all the dealer did to fix it was put a new check valve problem solved.
Old Mar 30, 2007 | 01:31 AM
Silver_Dodge's Avatar
Silver_Dodge
Actually, your vacuum leak could be coming from anywhere, not just the intake. Do a search on this forum for "vacuum leak". Lots of people have posted where they found their vacuum leaks.
Old Mar 30, 2007 | 01:52 AM
shott8283's Avatar
shott8283
if its a 4X4.. could be the vacume lines coming from the t-case to the CAD on the front axle.. mine were rotted out (steel hardlines).. dealer had prebent ones and replaced them.. bam.. all fixed!
Old Apr 11, 2007 | 11:22 PM
N10SRAM's Avatar
N10SRAM
Thanks for the input about the vacuum leaks. When I had it at the dealer they said there was no other leaks except the intake. I will find out this Friday I am taking it in to have the the intake fixed. After digging around here in posts here I think that probably is it. Now how long of a job is that? they said it will take all day. Will they replace the plenum gasket or should I request that they do this?
Thanks again for the help.
Matt
