PWR Door Locks
Old Mar 29, 2007 | 11:04 PM
mcss8541's Avatar
mcss8541
Default PWR Door Locks
I own a 98 Ram ( See sig) and the driver's door lock will work sometimes and then not. Passenger side always work. I can hear the mechanism when I hit the button but that driver's door will not lock or out of the blue it will work. Any suggestions?
[IMG]local://upfiles/56056/F8BEAABDED3A4435BF8B139C4B34FA84.jpg[/IMG]
Old Mar 29, 2007 | 11:08 PM
Teggy_Boy's Avatar
Teggy_Boy
Default RE: PWR Door Locks
Mine does the same thing, except opposite. (My pass door lock is moody where-as my driver's side works flawless). I believe it's the switch itself.
Old Mar 29, 2007 | 11:20 PM
Ganderguy's Avatar
Ganderguy
My 98 does the same thing on the driver side, I was told it was the actuator. Don't know if that is right.
Old Mar 29, 2007 | 11:24 PM
982500Ram's Avatar
982500Ram
Mine did the same thing... I took the panel off the door and sprayed it all with penetrating oil.....works great now!
Old Mar 29, 2007 | 11:29 PM
mcss8541's Avatar
mcss8541
Thanks for the info, I'll try the penetrating oil and if that doesn't work then I'll try replacing the actuator.
Old Mar 29, 2007 | 11:33 PM
982500Ram's Avatar
982500Ram
by the way....the clips holding the door panel on were really hard to get off without breaking something. I cut some with a hacksaw blade and replaced them with new ones so I didn't have to pry on them and break anything. If your door panel has been off this probably won't be an issue.
I think their is a special tool for it ....but I don't own it.
Old Mar 30, 2007 | 01:33 AM
Socha_62's Avatar
Socha_62
The solenoid is going bad, get it at any parts store. Easy to fix.
