Fastman Encouragement
Old Mar 30, 2007 | 10:58 PM
2 Marks's Avatar
2 Marks
Default Fastman Encouragement
OK, the fastman arrived today. I am not the most savy person with tools but plan to take a poke at it tomorrow. Dan's instructions seem easy - am I in for a rude awakening?
Also, does the s bolt that comes with Dan's kit work for the 14 x round air intake? I read through Silver's post but didn't see the answer.
Lastly, does anyone know if a 4 inch filter fits under the hood within the 14 inch round filter system?
Thanks.
Mike
Old Mar 31, 2007 | 12:31 AM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Fastman Encouragement
The install is easy, just follow his instructions, and take your time. Make sure you reconnect everything you disconnect, and don't knock anything down into the intake either.
That s-bolt will work, if it is long enough for the filter assembly you get, but it is the right bend. Makes a good template too if you end up needing to make one that is longer.
Only way you will fit a 4" filter is with a body lift. 3" is the max, and that is a really really tight fit.
Old Mar 31, 2007 | 12:40 AM
2 Marks's Avatar
2 Marks
Thanks Silver, I will repot back after the project.
Old Mar 31, 2007 | 02:23 AM
Silver_Dodge
Post if you have problems too, plenty of folks on here can help you so you can get your truck back in running order.
Old Mar 31, 2007 | 12:57 PM
2 Marks's Avatar
2 Marks
Just picked up the Edlebrock 14x3 and a push-in breather. Finishing my coffee and hitting it. Stay tuned.
Old Mar 31, 2007 | 01:28 PM
bamory's Avatar
bamory
I put my Mopar air cleaner on using the s bolt supplied by Dan, worked great with plenty of room to spare.
Old Mar 31, 2007 | 02:21 PM
2 Marks's Avatar
2 Marks
Question, Dan's instructions say to reset the PCM. If I do this, do I have to de-install my Hypertech tuning and/or reinstall it after the PCM reset? Thanks much.
Old Mar 31, 2007 | 02:45 PM
2 Marks's Avatar
2 Marks
It appears my 14x3 base needs to be lifted a little bit to ensure nothing filters in under the housing. Should I have purchsed some sort of rubber grummit? Thanks.
Old Mar 31, 2007 | 03:17 PM
mcss8541's Avatar
mcss8541
DUMB QUESTION BUT ARE YOU INSTALLING A THROTTLE BODY? THE REASON I ASK IS BECAUSE THAT'S ON MY LIST OF THINGS TO DO TO MY 98 1500 5.9L.
Old Mar 31, 2007 | 04:22 PM
Silver_Dodge
ORIGINAL: 2 Marks
There should have been a rubber gasket on your TB from before. My Fastman also came with one. If not, you can get one at a parts store for very cheap.
