Check Engine light comes and goes...
Old Apr 2, 2007 | 01:38 AM
sagebrush07's Avatar
sagebrush07
Default Check Engine light comes and goes...
Hey everyone, I'm brand new here and a brand new owner of a 1998 Dodge Ram 1500, 4x4, Shortbox, extended cab, 5.9L...anyway my check engine light randomly comes and goes. Any ideas? I did a search and I read the coil may be going, but wouldn't that cause the light to constantly be on? Thanks,
Sage
Old Apr 2, 2007 | 02:17 AM
DieselDemon's Avatar
DieselDemon
Default RE: Check Engine light comes and goes...
I am not sure if your Ram can do the,............ on-off-on-off-on.....key thing to retrieve trouble codes.
I loaned my manual to a fellow df'er and it's too late to call and have him email that page to me. Someone on here will post it, I would bet.
Good luck with your ride.
Old Apr 2, 2007 | 06:00 PM
sagebrush07
what's the on-off-on-off-on thing?
Old Apr 2, 2007 | 06:05 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Is it blinking at random and then ceasing? If so, then you have a misfire.
Old Apr 2, 2007 | 06:16 PM
hillbillyman06's Avatar
hillbillyman06
Mine does the same thing and when I check the code it tells me its an O2 sensor (both have been replaced). It has been doing it since I bought it with 52,000 on it and now I have104,000.
Old Apr 2, 2007 | 07:08 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: hillbillyman06
Check all of your ground connections. The most odd code can come from a dirty ground.
Old Apr 3, 2007 | 01:14 AM
TMS Bill's Avatar
TMS Bill
ORIGINAL: sagebrush07
It's a way to pull OBD codes from the PCM using the ignition key ... you can't do it cause you have a 98. You have to get a code reader (or go to a place that will pull them for you).
Old Apr 3, 2007 | 12:19 PM
hillbillyman06
ORIGINAL: VWandDodge
Thanks, I am not to worried about because it doesn't affect the performance of it..I just put a piece of electrical tape over it and don't see it!
Old Apr 3, 2007 | 12:44 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
That's the worse thing you can do, because one minor problem can swell into costly repairs. It's a domino effect. Go to your local FLAPS and have them pull the codes. They do it for free.
Old Apr 3, 2007 | 02:42 PM
Socha_62's Avatar
Socha_62
Read the codes...that might tell you something
