Simple question: How much higher is the 2500 compared to 1500
Old Apr 4, 2007 | 03:14 AM
berkoWitZ's Avatar
berkoWitZ
Default Simple question: How much higher is the 2500 compared to 1500
Did a search but couldn`t find the right terms with my limited english. How much higher is the 2500 compared to 1500, my guess is about 2.5 inches?
Thanks!
Old Apr 4, 2007 | 02:33 PM
berkoWitZ's Avatar
berkoWitZ
Default RE: Simple question: How much higher is the 2500 compared to 1500
Nobody knows...?!
Old Apr 4, 2007 | 02:36 PM
bamory's Avatar
bamory
My Sport actually sets higher side by sidethan a 2500 I know of, best I can tell ya
Old Apr 4, 2007 | 03:01 PM
akyne's Avatar
akyne
A 4wd 2500 sits about 2 inches higher off the axles than a 4wd 1500.
Old Apr 4, 2007 | 03:12 PM
Silver_Dodge's Avatar
Silver_Dodge
Most say about 2", but when I installed my 2" lift on my 1500, I was higher then any stock 2500 I would park next too, and also ones running bigger tires (but just barely). I would say it is less the 2", like 1.5". From the factory, it was probably 2", but they are sagged by now, so that is probably why a fresh 2" lift on my 1500 made me taller then a stock 2500.
Old Apr 4, 2007 | 03:20 PM
bamory's Avatar
bamory
I know that I am taller than stock 4wd 2500 ( I park next to one @ work)with no lift kit on mine, is there a reason behind you needing to know this?
Old Apr 4, 2007 | 03:41 PM
berkoWitZ's Avatar
berkoWitZ
Thanks for the great answers
I have a 1998 Dodge Ram Sport 4x4 5.9, I needed to know that because every 2500 ram I see on the street is notably higher than mine (about 2 inches but it is noticeable), mine is stock. I have a modified Land Rover Defender with a 7 inches kit, and that´s my ride for all days, thats why I see the 1500 too close to the street
I want to install a leveling kit to my truck but want to be the same or 1 inch higher than a 2500...
But in your case bamory is weird, how is your 1500 higher than a 2500 if it is stock?
Old Apr 4, 2007 | 03:58 PM
Socha_62's Avatar
Socha_62
I'd say 2-3"
Old Apr 4, 2007 | 04:34 PM
V10's Avatar
V10
From 1/4"- 1-1/2"
http://dodgeram.info/2001/dimensions.html
