Removing the PCM
Old Apr 5, 2007 | 02:48 PM
ripto's Avatar
ripto
Default Removing the PCM
Just to start another thread instead of stealing Silvers, is it necessary to remove the 3 plugs when I go to remove the Jet chip? It is in the plug closest to the driver's side. The instructions from Jet say to remove the PCM from the firewall, then take out the plug on the right, put the Jet in, then the plug, then put the PCM back on. Why do you have to remove the PCM from the firewall to begin with? Can't I just unplug it from where it is?
Old Apr 5, 2007 | 02:56 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Removing the PCM
I don't see why you would need to remove it from the firewall. Everytime I have had mine off, I remove the plugs before I remove it from the firewall. If all you need to do is remove the plug, then why bother removing the PCM from the firewall.
Old Apr 5, 2007 | 03:05 PM
spaz_22's Avatar
spaz_22
are you installing the jet chip with your hypertech program????will that screw things up?
Old Apr 5, 2007 | 03:08 PM
Silver_Dodge
I think he is removing his jet chip.
Old Apr 5, 2007 | 03:13 PM
ripto's Avatar
ripto
Yeah I will be removing the Jet chip, driving the truck around to hear the ping situation without it, and then try out the hypertech. Now, where are these clips I should watch out for?
Old Apr 5, 2007 | 03:15 PM
padodgeram's Avatar
padodgeram
theres a clip on the back side of the chip......rember disconnect the battery before you do this...and the jetchip website has the directions to hook and unhook the jetchip.
Old Apr 5, 2007 | 03:28 PM
ripto's Avatar
ripto
Disconnect the negative, or both?
Old Apr 5, 2007 | 03:29 PM
padodgeram's Avatar
padodgeram
the NEG.will work.
Old Apr 5, 2007 | 03:30 PM
ripto's Avatar
ripto
Thanks guys, going outside to do this right now.
Old Apr 5, 2007 | 03:40 PM
ripto's Avatar
ripto
Lol, question: how do you remove the plug? What do you have to do with that little tab in the middle? Lift it up?
