Is this a problem or are the years just catching up with my truck?
Old Apr 10, 2007 | 11:43 PM
Dodgeboy328's Avatar
Dodgeboy328
Default Is this a problem or are the years just catching up with my truck?
I had a cat-back Flowmaster 40 exhaust put on my truck about a year ago and it just doesn't sound as good anymore. It just sounds stuffy. When I first got it I could crank up, pull out on the highway, and floor it and the truck roared. But now it just sounds muffled. Plus the truck is not near as responsive as it used to be. I've considered cutting the exhaust back and making a set of turndowns, but I don't even know if the exhaust is the problem. Guess it just boils down to not getting true duals. I kick myself everytime my neighbor passes by.
Old Apr 11, 2007 | 01:15 AM
TMS Bill's Avatar
TMS Bill
Default RE: Is this a problem or are the years just catching up with my truck?
Do you still have a cat on your truck?
Old Apr 11, 2007 | 01:19 AM
Buc's Avatar
Buc
Sounds like a plugged cat. I seen something on here where you can check it with a temp gun aimed at the intake and output of the cat. I cant remember which should read hotter to indicate a good cat vs bad cat.
Old Apr 11, 2007 | 11:11 PM
Dodgeboy328
Yeah, there's a cat on my truck. But it was replaced by the original owner due to being plugged when the truck was brand new. Besides I thought a plugged cat rattled really bad.
Old Apr 11, 2007 | 11:21 PM
TMS Bill's Avatar
TMS Bill
No ... a disintegrating cat rattles ... a (badly) plugged cat makes the engine sound throaty. Just because it was replaced once doesn't mean it's still good.
Old Apr 12, 2007 | 12:24 AM
ramdodge97's Avatar
ramdodge97
A clogged cat will definitly cause u to lose power and throttle response you sould try removing the cat an test drive the truck to see if u gain any power back to eliminate what migh be wrong with it
Old Apr 13, 2007 | 10:41 PM
Dodgeboy328
You can take the cat on and off like that? I didn't know that. How do you get it off?
Old Apr 14, 2007 | 12:15 AM
Ram_Sport's Avatar
Ram_Sport
no, you have to cut it off
Old Apr 14, 2007 | 10:40 PM
jram99's Avatar
jram99
I had 2 factory cats on my truck go bad. The first was at about 1.5 years old, the 2nd one about 5 months later. Put duals on with 2 highflow cats and haven't looked back since. Don't know about now, but the in 99 the factory cats sucked!! Good luck. Jeff.
