Need help
Old Apr 11, 2007 | 02:51 PM
DODGE 4X4's Avatar
DODGE 4X4
Default Need help
yesterday I replaced the front hub assemble and u-joints on my 01 1500 . Now it will not go into 4 wheel drive. if any one can help i would greatly appreciate it
Old Apr 11, 2007 | 03:21 PM
94ram4x4 5.9's Avatar
94ram4x4 5.9
Default RE: Need help
CAD not working? check your vaccum lines. I'm guessing it worked fine before the swap?
Old Apr 11, 2007 | 04:21 PM
DODGE 4X4's Avatar
DODGE 4X4
CAD? The vaccum lines are hooked up.But there is still no 4x4 light
Old Apr 11, 2007 | 06:40 PM
94ram4x4 5.9
If you 4wd light isn't coming on, then the CAD (Central Axle Disconnect) is not engaged, check for any loose or worn vaccum lines and possibly replace with a hard 1/8" vaccum line. Could have a leak or be collapsing somewhere in line.
Old Apr 11, 2007 | 07:12 PM
DODGE 4X4's Avatar
DODGE 4X4
Im looking at it right now and the thing that the vaccum lines connect to is loose . Although i don't see how that would have got screwed up when i removed the axle shafts i was thinking that is was some kind of actuator.And eventhough it is supposed to be shift on the fly i have always had to be moving to get the 4 wheel drive to engage, so if you ever got stuck in 2 you could never get it to lock in 4
Old Apr 11, 2007 | 09:50 PM
TMS Bill's Avatar
TMS Bill
That's what "shift on the fly" means ... the chances of the splines being lined up perfectly while sitting still is pretty remote. You have to be moving to get the splines positioned correctly so the CAD can lock the axle shaft.
