Clearance on the M1 and how it will work....
Old Apr 14, 2007 | 03:07 PM
mikerados21's Avatar
mikerados21
Default Clearance on the M1 and how it will work....
Okay im looking to buy the M1 Intake for my 98 dodge ram 5.2. just a few questions if this will work.
I have a holley throttle body that is 53mm that fits on the stock intake. If i replace my stock intake with the m1 will the holley tb fit on that Intake? and will it be the same clearance so i can still fit the mopar round filter setup under there? im just worried about fitting and clearance cuz that filter was mighty tight...... Thnx guys....
PS: where can i find some good injectors for my truck. Ive been looking everywhere.... thnx again...
Old Apr 14, 2007 | 04:44 PM
Ganderguy's Avatar
Ganderguy
Default RE: Clearance on the M1 and how it will work....
I did a post yesterday about the clearance issue and I was told that the M1 was the same height as the original manifold. and yes the holley throttle body will fit if you get the right intake because there is a 2 bbl and a 4 bbl intake. match it up to the TB you have and your good to go.
Old Apr 14, 2007 | 05:26 PM
Bigschwerm's Avatar
Bigschwerm
ORIGINAL: mikerados21
you wont need injectors for your setup...spend your money elsewhere....
