rearend noise
Old Apr 14, 2007 | 11:48 PM
royiii's Avatar
royiii
Default rearend noise
98 1500 4x2, the wife blew out the rearend and I got another one from a wrecking yard. I got a complete rear axle ***.(brake drum to brake drum). I put it in the truck and there is a whine at 30mph and up it stops when I let off the gas. Any ideas what it could be? thank you
Old Apr 14, 2007 | 11:56 PM
kayakman's Avatar
kayakman
Default RE: rearend noise
Definitley a bearing whine, but which one?? Had the carrier go in mine, which took out all the bearings.
It cost me almost 2300.00 for parts and labour.
Old Apr 15, 2007 | 06:30 PM
cableguy's Avatar
cableguy
Mine too, luckily it was under warranty at the time.
Old Apr 16, 2007 | 01:29 PM
Glideman88's Avatar
Glideman88
Sounds like your pinion shaft bearing is making noise.
Old Apr 16, 2007 | 01:55 PM
982500Ram's Avatar
982500Ram
I had to have the bearings redone in my dana 60 axle recently. It was $125 labour from a local drivtrain shop $400 total (Canadian $) it was whining at the same speed 50 kph and up. I figured I would fix it before it blew all to heck and it cost me a lot more.
Old Apr 17, 2007 | 12:26 AM
TMS Bill's Avatar
TMS Bill
Rear pinion bearing ... if it whined during coast it would be the front pinion bearing.
