lug nut size???
Old Apr 16, 2007 | 01:51 AM
spaz_22's Avatar
spaz_22
Default RE: lug nut size???
you can buy larger lugnuts with the same size thread so that is not a problem, you can go to any local auto store, bring both lugnuts and say what you need. iirc all third gens are 5 on 5.5 just like the 2nd gens so they will fit the pattern. as for tires, it won't be hard to find them, but they are pretty expensive...
Old Apr 16, 2007 | 01:57 AM
dodge5.9liter's Avatar
dodge5.9liter
ok so i have no problem of fitting them on my truck?
he sent me more info because i am worried.
part # M09518955312[/align]offset 12mm[/align]18x9[/align]hub 108mm[/align]pcd 5x139.7[/align][/align]what is pcd???[/align][/align][/align]
Old Apr 16, 2007 | 02:10 AM
spaz_22's Avatar
spaz_22
The pcd is the lug pattern which is 5 on 5.5 in standard
Old Apr 16, 2007 | 02:29 AM
dodge5.9liter
then what does the pcd 5x139.7? thats not 5 on 5.5 is it?
Old Apr 16, 2007 | 02:39 AM
spaz_22's Avatar
spaz_22
pcd is the lug pattern. 5 x 5.5 is the same as 5 x 139.7mm.......139.7mm equals 5.5 inches
Old Apr 16, 2007 | 02:44 AM
dodge5.9liter
so they will for a fact fit on my truck! i just dont want to get screwed. will i be able to find a 31inch tire to fit on them you think? spaz_22 you have been great help thanks for all of it!
Old Apr 16, 2007 | 02:54 AM
dodge5.9liter
spaz_22 don't let me down yet!!! sorry for all the questions.
Old Apr 16, 2007 | 03:20 AM
spaz_22's Avatar
spaz_22
they will fit your truck, but you may need to buy new lug nuts..i doubt it but it is a possibility...just check out any online tire website or go into a local store. i found some 285/60r18's...11.22inches wide, by 31.36 is the clossest to 31 you'll get. But like i said they can get pretty pricey depending on the tire design you want...but you want some mts you'll have to go with a larger tire....you can get some bfg at's 285/65r18's that are a little over 32 inches for almost 250 dollars...go to this site and play around with the aspect ratios..the first number is width of the tire in mm, the second is the aspect ration (height of sidewall by percentage of the width)..http://1010tires.com/TireSizeCalculator.asp
Old Apr 16, 2007 | 03:42 AM
dodge5.9liter
thanks alot for your help!! you need to get an award!!
I appreciate it alot! that will be the only problem i wil run into is tire size it looks like thanks again!
Old Apr 16, 2007 | 03:52 AM
dodge5.9liter
I am trying to find some pro comps or mickey thompson's
