lug nut size???
Why would you limit yourself to "cheap" tires? I realize you may be on a tight budget but if this is the case ... why change out perfectly good stock rims for 3rd Gen stuff? For looks? How frugal ...[>:]
Hmm well there not really 3gen rims! http://new.photos.yahoo.com/police66...60762344858246
there they are they are aftermarket they just are on a 3rd generation truck uhh duh![sm=icon_ladiesman.gif][sm=owned.gif][sm=thanx.gif][sm=groupwave.gif]
check out tirerack..com...discounttires.com....or your local shop....you might check a salvage yard, or any other place that would sell used tires...that would be your best bet...oh, and is this going on a 2wd or a 4wd, if 4wd you can fit 32's on it and they might cost a little less becuase of the sidewall...
It is 4x4. I checked discount tirejust didnt really find what I was looking for. Want a more aggressive tire then the wrangler I think it was. You've been a lot of help I will check the tire rack now thanks. I could go to a used tire shop too i guess. Or see if discount tire has any. thanks
Well ... aftermarket instead of 3rd Gen ... who gives a rat's *** ... the point (which you missed entirely) was that you blew all your cash on bling rims and now you're reduced to begging for tires to put on them. Used tires ... puhlease.
Get your priorities straight.
Ohh is that right Got 18's for $250. 4months old. Call that a waste of money??[sm=jawdrop.gif][:-]wake up they were $700 when he first bought them. You called that a waste of money ( "blew off"?) Also FYI Im not begging for tires I am begging for Help![sm=owned.gif] Won't you put some forward. Don't have any don't post. Simple.
[sm=bling.gif]Who still uses that term?[sm=GrowUp.gif][sm=thanx.gif]
Also Spaz_22 has been great help.
Plus I have found tires Mickey Thompson's ATZ[sm=loser.gif]
Spaz_22 once again thanks.
TMS BILL don't come on here thinking that you know everything. I didn't see you post one bit of good information. I have money just Didn't want to spend $500 per tire would you?? [sm=thanx.gif]
So read before you post I did say cheapest which is about $200per tire.
Can i say this again [sm=guilty.gif][sm=owned.gif]
