fog lights
Old Apr 15, 2007 | 07:03 PM
dobbie146's Avatar
dobbie146
Default fog lights
i've got a 99 ram sport 4x4. Does anyone know how to turn the fog lights off when the key is turned back??
i can't have the radio on parked without the fog lights being on??
[align=left] [/align]
Old Apr 15, 2007 | 07:43 PM
spaz_22's Avatar
spaz_22
Default RE: fog lights
the only time my foglights are on are when the parking lights are on and or headlights...
Old Apr 15, 2007 | 09:20 PM
Scottr1110's Avatar
Scottr1110
i dont know if the newer ones have it but i know in 96 they had daytime running lamps mabe thats it dont know i u could just unplug the box
Old Apr 15, 2007 | 09:36 PM
stick1994's Avatar
stick1994
Daytime running lights can be shut off by pressing the e-brake. The fog's shouldn't be on unless the parking/headlights are on though...
Old Apr 15, 2007 | 10:11 PM
royiii's Avatar
royiii
you cound always splice and wire a toggle swich under the dash
Old Apr 16, 2007 | 11:49 AM
dobbie146's Avatar
dobbie146
i tried putting the e brake on and that didn't help.
Old Apr 16, 2007 | 04:30 PM
stick1994's Avatar
stick1994
Are they the stock fogs? I would check the wiring on them, sounds like someone wired them to come on when the key was turned.
Old Apr 16, 2007 | 05:35 PM
DieselDemon's Avatar
DieselDemon
ORIGINAL: stick1994
That would be my first thought.
Pull the cover off the interior fuse box and see if there is a small wire coming off the top of the fuse panel. Off the top meaning where you pull and replace fuses. Just like stick said.......are they factory fogs?
There might be a relay somewhere as well.
Good luck with your ride.
Old Apr 16, 2007 | 08:20 PM
jisthangin01's Avatar
jisthangin01
I agree. The only time my fog lights come on are with my switch. Actually, thats the only time any outside lights come on. I didn't know these trucks had daytime running lights.. Not all of them came with them, right?
Old Apr 16, 2007 | 08:35 PM
mopar crazy's Avatar
mopar crazy
ORIGINAL: jisthangin01
I I didn't know these trucks had daytime running lights.. Not all of them came with them, right?
My '99 Ram does not have daytime running lights. I hate those daytime lights, so annoying.[:'(]
My foglights are the same as everyone elses, come on only when I pull the headligh switch in either parking light / headlight mode.
