coolant type
Old Apr 16, 2007 | 10:43 PM
jacobl's Avatar
jacobl
Default coolant type
What kind of coolant does a 1996 ram 1500 with the 360 use?
I am replacing a water pump and need to know. How muchcoolant does it require?
thanks
Old Apr 16, 2007 | 11:23 PM
stick1994's Avatar
stick1994
Default RE: coolant type
[sm=icon_rtfm.gif]
Old Apr 16, 2007 | 11:27 PM
jacobl's Avatar
jacobl
I have no manual.
Old Apr 16, 2007 | 11:33 PM
dhvaughan's Avatar
dhvaughan
as far as i know you just use plain old green anti-freeze (ethylene glycol). the red stuff if Dex-cool and i think its only for GM products and i think it sludges up bad. i just did my water pump and drained the block using the drain plugs beside the motor mounts. i bought 2 gal of full strength and mixed it 50/50 and used about 3 gal of mix. mix with distilled water to avoid mineral deposits.
Old Apr 16, 2007 | 11:47 PM
jacobl's Avatar
jacobl
thank youvery much dhvaughan!
Old Apr 17, 2007 | 01:20 AM
TMS Bill's Avatar
TMS Bill
I drained out the green stuff and replaced it with orange. It lasts longer and is supposed to extend the life of your seals and pump bearings. Besides ... it looks like Tang. [&:]
Old Apr 17, 2007 | 01:04 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: dhvaughan
IIRC, Chrysler tried Dexcool and it reacted with some of the components in engines and destroyed them. My 2002 Cavalier came out of the factory with Dexcool and I've never had a problem. The car now has 131K miles. I know that the GMC Jimmy and S10 Blazers had problems with Dexcool. Also, if you try to switch from green coolant to orange, or vice versa, and don't *thoroughly* flush the engine they will react with each other and sludge the water jackets.
I recommend sticking with regular green coolant.
