Radio/Speaker problems.
Old Apr 18, 2007 | 04:46 AM
Rakaric's Avatar
Rakaric
Default Radio/Speaker problems.
Ok so for the past few months my dad has been saying that after a while of using the stock radio/CD Player, eventually the playback just stops. The radio tho is still on. Soooo today we bought a new aftermarket radio with a CD player. I installed it and stuff. The radio worked fine for a while, but when I went to test the CD player, I was not getting playback at all. Then soon after I realized the sound to the radio wasn't working either once in a while. So I let it sit there and I wait for it to come on. All of a sudden the sound came back on. Spending an extra hour and a half mopre than neccessary...I got frustrated and took it to my Dakota. I plugged it in and EVERYTHING worked fine. So what's wrong with my dad's 2002 Dodge Ram, exactly?
Old Apr 18, 2007 | 04:56 AM
habeba86's Avatar
habeba86
Default RE: Radio/Speaker problems.
Does the ram have the Infinity system in it?
Old Apr 18, 2007 | 05:02 AM
Rakaric's Avatar
Rakaric
Yes it does
Old Apr 18, 2007 | 05:57 AM
Zeppelinrocks's Avatar
Zeppelinrocks
then you either have to bypass the amp or buy a wiring harness that can include the amp
Old Apr 18, 2007 | 01:17 PM
Rakaric's Avatar
Rakaric
ORIGINAL: Zeppelinrocks
Yea...why would I need to do this if the system and the original radio was stock? I would imagine everything would be hooked up right to begin with. I already have a wiring harness for the aftermarket radio. With the radio stock I was having problems, and so was the aftermarket radio.
Old Apr 18, 2007 | 02:24 PM
habeba86's Avatar
habeba86
You could have a grounded speaker wire..but it seems unlikely with all stock stuff still in there and the vehicle is not that old. With the afermarket radio you need to hook up the remote turn on lead to the blue/white wire on the factory harness adaptor.
Old Apr 18, 2007 | 03:17 PM
Rakaric's Avatar
Rakaric
On the factory harness there is no extra wire to plug in the blue/while wire. All the wires from the factory harness, to the sony adapter are connected. Which are all positive, ground, and speaker wires.
Old Apr 19, 2007 | 02:09 AM
habeba86's Avatar
habeba86
Do you have a harness that plugs into the factory harness, then you had to splice the sony harness to it?
Old Apr 19, 2007 | 02:11 AM
Rakaric's Avatar
Rakaric
I just bought an adapter harness, i didn't wanna deal with splicing.
Old Apr 19, 2007 | 02:13 AM
habeba86's Avatar
habeba86
From CC? That plugs into the factory plug...then 2 plugs that are the same plug together...then a plug that goes into the sony?
