CB antenna mounting
Old Apr 18, 2007 | 01:49 PM
rdnkjeeper's Avatar
rdnkjeeper
Default CB antenna mounting
Hey all,
I searched but didn't see too much information about mounting a CB antenna. Where are you mounting yours? What kind of antenna you using?
Thanks
Old Apr 18, 2007 | 02:51 PM
tdmopar59's Avatar
tdmopar59
Default RE: CB antenna mounting
well rite now i have a magnet one on my roof just threw it up there with the wire going out the back drivers side window.... on my buddies he has a back rack and duel antennaes i ran them under the cab and in then mounted the antennaes to the rack my other buddies with duels we mounted them on the front of the bed and ran the wires the same way except my buddy with a ford i found a way into the cab through a cab vent
Old Apr 18, 2007 | 04:11 PM
red98ram's Avatar
red98ram
iv seen some with dual firestick's i think there called, they are like 2ft long and you can mount them on each side of the truck right behind the cab..
Old Apr 18, 2007 | 04:15 PM
tdmopar59's Avatar
tdmopar59
yea they are called fire sticks and you can get them in a variety of sizes the 3 pairs ive installed on my buddies trucks are 4 foots
Old Apr 18, 2007 | 04:28 PM
Socha_62's Avatar
Socha_62
I have dual 4' fiberglass antenna's mounted on each side of the tool box. On the front of it, between the cab and tool box. Works fine, little high SWR since only about 1/2 the antenna is completely above the cab but its not up to 3 or anything.
Old Apr 18, 2007 | 04:30 PM
96_59L's Avatar
96_59L
i got dual wips on the mirrors. they are about 2 ft. got old brackets though. the only problem is that the wire i have going through the door and is pinchin the weatherstripping and lets rain in. so any ideas on where to reroute them is appreciated
Old Apr 18, 2007 | 04:32 PM
tdmopar59's Avatar
tdmopar59
you could put them under the hood and then through the firewall but i would reccomend a new mounting location... is there a particular reason you have them on your mirrors?
Old Apr 18, 2007 | 04:33 PM
96_59L's Avatar
96_59L
got the brackets free
Old Apr 18, 2007 | 04:34 PM
96_59L's Avatar
96_59L
is there a big enough hole for the connector to go through?
Old Apr 18, 2007 | 06:03 PM
tdmopar59's Avatar
tdmopar59
you could make a hole and then caulk around it if you wanted to
