52mm is in!
Old Apr 21, 2007 | 09:35 AM
steve05ram360's Avatar
steve05ram360
Default RE: 52mm is in!
ORIGINAL: IndyRamMan
eh, its ok. I guess i have to wait and see. It feels dogish. It burns out so gimply. It feels slightly torquier but theres a noticable lack of performance imo. The throttle responce is greatly improved though.
this is the main benifit to the 52mm TB on a 5.9 motor... how did it lay rubber before? what other mods do you have? when I put mine on, I didnt reset the pcm and noticed more power from the get go. I never did change much after the initial drive, even after resetting the pcm.
are you sure there's a 5.9 in there? (the CID is stamped on the block above the starter) if you have a 5.2 in there for some reason you would get less than expected results.
Old Apr 21, 2007 | 05:04 PM
Bigschwerm's Avatar
Bigschwerm
i think you will see more of a gain from the TB after you open your exhaust and either mod and port your intake or go with the M1....
Old Apr 21, 2007 | 05:56 PM
lv360ram's Avatar
lv360ram
Most of the driving I do in my Ram is on an interstate at 2000rpm. I need more torque to go up hills without coming out of overdrive. Would the 52mm TBincrease thetorque at 2000rpm?
Old Apr 21, 2007 | 07:38 PM
spaz_22's Avatar
spaz_22
fast man recommends the 50 mm for 5.9's if your wanting more torque for towing and hills ect.
Old Apr 22, 2007 | 01:19 PM
AAA4948's Avatar
AAA4948
What size is the stock TB on 5.9's?
Old Apr 22, 2007 | 02:59 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: steve05ram360
Oh its a beast now. I definately notice a diffrence, its been like 350 mi since i put it on. Crusin on the hwy doesnt take any effort, and accelerating up to speed is seamless and easy now. Burnin rubber was always easy, i havent tried it, but i did spin from like a 5mph roll when i wot'd last night.
ORIGINAL: Bigschwerm
Im assuming the same thing. Dang LT's on backorder till may the 8th. Guess ill haveta wait to find out .
quote]ORIGINAL: spaz_22
[/quote]
This truck doesnt tow or whatnot.
ORIGINAL: AAA4948
I think its like 47 something.
Old Apr 22, 2007 | 05:18 PM
spaz_22's Avatar
spaz_22
I recommended the 50mm for lv360 ram cuz he said he wanted more power around 2000rpms....i know your after speed and higher rpms indyramman
Old Apr 23, 2007 | 12:27 AM
steve05ram360
I'd still go with the 52mm for the 360... you can control the torque with other mods.
Old Apr 23, 2007 | 01:28 PM
lv360ram's Avatar
lv360ram
What mods would give me more torque at 2000rpm?
