No power
Old Apr 20, 2007 | 09:12 PM
TheForce55555's Avatar
TheForce55555
Default No power
My 1996 Dodge Ram 1500 Does not have the power that it should have. Especially on the highway, i can't keep it at cruising speeds. I even downsized to 29 inch tires! Anybody have any ideas? Also my motor is good, only 70,000 miles
Old Apr 20, 2007 | 09:26 PM
bander's Avatar
bander
Default RE: No power
No power at all or accelerating on highway?
I had the same problem trying to speed up on highway or starting form a stop light, would have to mash the pedal.
It was a clogged cat on mine.
Old Apr 20, 2007 | 10:56 PM
TheForce55555
It just falls flat on its face, I can forget about going up a hill in overdrive, just bogs down. My Cat is not clogged i gutted it awhile back
Old Apr 21, 2007 | 02:41 AM
royiii's Avatar
royiii
Take it in to a shop and have them hook it up to a computer, maybe it's a bad sensor. Is your check engine light on?
Old Apr 21, 2007 | 09:08 AM
steve05ram360's Avatar
steve05ram360
check you fuel pressure, make sure it's at 49psi or so, the spec is 49psi +/- 5 IIRC, if your at 44 or below, it could explain your power loss. make sure you test it under load as well (drive it with the guage on).
Old Apr 21, 2007 | 06:20 PM
lv360ram's Avatar
lv360ram
If you haven't seen the other thread, here it is https://dodgeforum.com/m_777069/tm.htm.
Old Apr 22, 2007 | 03:50 PM
TheForce55555
Thanks Guys, great Info
