torque specification
Old Apr 21, 2007 | 05:44 PM
macelano's Avatar
macelano
Default torque specification
I just replaced the drive shaft u-joints, andIneed the torque specification for the drive shaft to rear diff. bolts.I have a Dodge Ram 1500.
Any help would be appreciated.
Thank you
Old Apr 21, 2007 | 05:55 PM
DieselDemon's Avatar
DieselDemon
Default RE: torque specification
Maybe the year, engine, etc.
You're talking about the two straps that bolt down over the u-joint caps, correct?
Old Apr 21, 2007 | 09:31 PM
macelano's Avatar
macelano
There are actually no straps on the rear, unlike the front. The flange that attaches to the u-joint and then then to to drive shaft. It is a four bolt connection (15mm). The year is 2000 5.2 L, 4x4. Thanks
Old Apr 23, 2007 | 10:37 PM
TMS Bill's Avatar
TMS Bill
The companion yoke to companion flange bolts are to be torqued to 80 ft-lbs.
