Confused about O2 Sensor Replacement!
Old Apr 27, 2007 | 03:06 PM
HammerNailKid's Avatar
HammerNailKid
Default Confused about O2 Sensor Replacement!
Hey Kids,
I'm new to the forum and I've read a lot of stuff on here about O2 sensors. My question is which one(s) do I replace? I'm confused about the whole rightside/leftside and upstream/downstream thing. Obviously I'm no expert at this stuff. Just wanna know how many and which ones. Hoping it will help with throttle response, surging, etc. And I've already ordered a new tp sensor (just havent installed yet).
-1998 Ram 1500 5.2L 4WD
-125,000 miles
Thanks
Old Apr 27, 2007 | 07:00 PM
hotrodz's Avatar
hotrodz
Default RE: Confused about O2 Sensor Replacement!
The left and right are as you sit in the drivers seat. As I understand it, some have a sensor on each side just beyond the exhaust manifolds, and some only have one on the pass. side. Upstrem and downstream is refering to the location of the sensor in relation to the cat converter. hope this helps a little.
Old Apr 27, 2007 | 08:17 PM
ASH's Avatar
ASH
More than likely, you only have two, one right before the CAT and one after. If you don't see one right before the CAT, look on the pipes as described above.
Old Apr 27, 2007 | 11:20 PM
DodgeRam2500CTD's Avatar
DodgeRam2500CTD
My 98 5.9 had 1 before cat and 1 after. I went and picked em up at NAPAfor about $67.00 a piece.
Old Apr 28, 2007 | 06:25 PM
HammerNailKid
Thanks for the clarification guys..i'll swap em out when I get my truck back from the paint shop.
