CAD unplugged on my front axle?
Old Apr 29, 2007 | 01:37 PM
hkspwrsche's Avatar
hkspwrsche
Default CAD unplugged on my front axle?
I didnt notice it before and when I originally bought it I assumed that it was all fine when I put the lever into 4wd. I read now that it doesnt work with out this CAD and the 4wd light should have come on. Any reason that someone would unplug it?
Help
Thanks
Harold
Old Apr 29, 2007 | 03:04 PM
THEGOLDPRO's Avatar
THEGOLDPRO
Default RE: Something unplugged on my front axle?
im alittle confused, so your saying your 4wd does not work and something is unplugged in the front axle???
Old Apr 29, 2007 | 05:36 PM
hkspwrsche's Avatar
hkspwrsche
seems to work but something is unplugged on the front axle- What does it do?
Old Apr 29, 2007 | 07:21 PM
THEGOLDPRO's Avatar
THEGOLDPRO
go take some pics of what your talking about maybe that will help out.
Old Apr 29, 2007 | 11:28 PM
hkspwrsche's Avatar
hkspwrsche
I'll do that sometime this week. Putting it in 4wd is done with the lever manually so this doesnt have any effect on it, right?
Old Apr 29, 2007 | 11:59 PM
THEGOLDPRO's Avatar
THEGOLDPRO
no it's still vacumn operated as well, just because the lever goes in doent mean its in 4wd
Old Apr 30, 2007 | 12:47 AM
BFR's Avatar
BFR
the only solinoid on the front axle is the central axle disconnect. an yes this will mean that ur 4 wheel drive wont work. the central axle disconnect acts just like hubs on older vehicles. so essentally the hubs on it are unlocked.
Old Apr 30, 2007 | 03:33 AM
hkspwrsche's Avatar
hkspwrsche
Should I be worried about why this was unplugged? Is unplugging it somekindofbypass in case the 4wd is not working? I only bought it recently and put the lever in 4wd to test it for noise but, just noticed the solenoid unlpugged yesterday.
Guess I should just plug it in and see what happens.
Old Apr 30, 2007 | 12:17 PM
hkspwrsche's Avatar
hkspwrsche
Just bumping this to the top to see if unplugging it would mask some kind of problem.
I decided not to just plug it in in case it was due to someone installing a new gear ratio in the rear but, not getting around to doing the front? I'll wait till I can get ti on a lift.
