Turning Shimmy
Old Apr 30, 2007 | 03:20 AM
mdrohman's Avatar
mdrohman
Default Turning Shimmy
My truck sort of shimmies when I turn. It acts like its in 4wd (I don't really know that it isn't for sure besides the lever beingin 2hi and no light on the dash). The steering wheel just jerkes just like if it were locked in 4wd. It doesn't do anything weird at highway speeds and I don't think it does anything weird below 5 mph - I can't really tell. Has anyone had anything like this before? Maybe its an alignment thing? Thanks for any responses.
Matt
PS - I did lift the front left wheel off the ground and spin it and the driveshaft didn't spin so I assume that also means its not in 4wd.
Old Apr 30, 2007 | 03:28 AM
Captain Squalus's Avatar
Captain Squalus
Default RE: Turning Shimmy
ORIGINAL: mdrohman
Matt
If just the left front was off the ground and the drive shaft didn't turn somthing is broke!
When you turn one of the three (LF,RF or DS) if all the gears in the diff are intact and the axles are not broke one of the other two has to turn.
Old May 1, 2007 | 12:55 AM
TMS Bill's Avatar
TMS Bill
Nope ... the inner half shaft on the passenger side is turning in the opposite direction of the driver's side. The driveshaft never moves until 4wd is engaged.
Old May 1, 2007 | 02:48 AM
Aubrey's Avatar
Aubrey
What year and how many miles? Mine was doing something very similar. Bad ball joints.
Old May 1, 2007 | 06:30 AM
Captain Squalus
ORIGINAL: TMS Bill
Only on the old ones with the cad system.
Old May 1, 2007 | 07:44 AM
Crabman's Avatar
Crabman
Your frontuniversal joints are bad. I had the exact same problem. It felt like I was in four wheel drive on dry pavement. Only happened at slow speed because you would never be able to turn the wheel that sharp at high speeds. Not a tough job but plan on a couple of hours.
Old May 1, 2007 | 10:39 PM
TMS Bill's Avatar
TMS Bill
ORIGINAL: Captain Squalus
ORIGINAL: TMS Bill
I would hope that's what he's talking about ... all the 2nd Gen 4x4's I know of use the CAD system.
