no head lights
Old Apr 30, 2007 | 09:52 PM
armark's Avatar
armark
Default no head lights
My 2001 dodge ram quad cab with a 5.2l. I have day time running lights, I have highbeams but no headlights. I cant find the relay if it has one.I checked the switch no burnt wires.
Old May 1, 2007 | 12:54 AM
dhvaughan's Avatar
dhvaughan
Default RE: no head lights
just went and looked at my 01. there are fuses in the end of the dash and also under the hood, in the power dist. box beside the battery. there are relays in there, but only for the quad light setup (sport ?). mine had no relays but several fuses. check presence of 12 volt power coming to (and through) all those fuses, and also to and through the headlight switch. the switch itself is known for burning out.
Old May 1, 2007 | 02:11 AM
armark's Avatar
armark
I did some digging.The problem was a broken wire clip in the wire harness at the highbeam switch. Thanks for your help.
Old Sep 6, 2007 | 12:37 PM
armark's Avatar
armark
Default RE: Steering stops
I have a 2001 quad cab 2 wd and the tires on it are oversized. Can I buy after market steering stops. My tires currently rubbing on the lower cotrol arm when the tires are turned to sharp.
Old Sep 6, 2007 | 10:46 PM
dhvaughan's Avatar
dhvaughan
you should already have factory stops that are adjustable.
see here. https://dodgeforum.com/m_651617/tm.htm
