How hard is it to install A Ring&Pinion set
Old May 2, 2007 | 11:40 PM
Big_N_Bad's Avatar
Big_N_Bad
Default How hard is it to install A Ring&Pinion set
Well I changed my Diff oil in the rear becuase i started to notice a clunking noise, and come to find out I borke two teeth off the pinion and 1 off the ring. so i am going to order a set, but my ? is how hard is it to install dont you have to do a special measure. i think i can get them in I just dont know about measuring them and adjusting them any help would be apprecative
BNB
Old May 3, 2007 | 12:16 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: How hard is it to install A Ring&Pinion set
If you haven't replace them before there some tools you'll need. In most cases the dealer have those tools.
Old May 3, 2007 | 12:26 AM
Socha_62's Avatar
Socha_62
And the dealer will charge you $800+ to do it. Get a ring and pinion from www.ringpinion.com or www.completeoffroad.com and do it yourself. They come with really really detailed directions. You might have to buy a dial indicator but its way cheaper then a shop doing it.
