which speed sensor?
Old May 3, 2007 | 01:23 AM
torqueman's Avatar
torqueman
Default which speed sensor?
Which one controls the speedo, the one in the trans or the one in the diff?
Old May 3, 2007 | 01:48 AM
TMS Bill's Avatar
TMS Bill
Default RE: which speed sensor?
Depends on what year your truck is ... 97 back ... tranny gear. 98 up ... RWSS on the rear axle.
Old May 3, 2007 | 10:24 AM
torqueman's Avatar
torqueman
It's a 99 and has both, so if it uses the one in the diff then whats the other for?
Old May 3, 2007 | 01:28 PM
master tech's Avatar
master tech
Site Moderator & Tech
The speed sensor is on the overdrive unit of the transmission, If the speed sensor goes out the transmission will still shift. The other sensor is for the ABS and will give you an open ABS circuit code.
Old May 4, 2007 | 01:04 AM
torqueman's Avatar
torqueman
But what if my ABS light is on and the speedo doesn't work until 25mph?
Old May 4, 2007 | 03:50 AM
Kev250R's Avatar
Kev250R
I'm betting it's the one in your rear diff. My '99 Ram did the same thing a couple of months ago. Changing the sensor in the rear diff. took care of my problem, got the speedometer working, and the ABS/Brake lights to go away.
HTH
--Kevin
Old May 4, 2007 | 05:06 AM
Sinister's Avatar
Sinister
Kevin is correct.
Old May 4, 2007 | 10:29 AM
torqueman's Avatar
torqueman
I'll give it a try.
Thanks
