Does the intake pan gasket and spark plug wire routing TSBs relate to a 2001 Ram 1500 5.9L 4x4? The copy I have says only up to 99. However, I think the intake is leaking on mine.
You can use the TSB but not for warranty repairs, Because it only goes 1999. Run the number 8 plug wire over the valve cover and run the number 5 over the other valve cover. And route the coil wire on top of the intake manifold.
