Jasper Transmission Band Adjustments?!
Old May 12, 2007 | 07:52 PM
cam5096's Avatar
cam5096
Default Jasper Transmission Band Adjustments?!
I have a Jasper Tranny with about 40000 miles on it and it does alot of hard shifting (upshifting), should I attempt to adjust the bands? Is this normal on a Jasper re-built? Is it risky adjusting the bands on my own?
Old May 21, 2007 | 10:00 PM
cam5096's Avatar
cam5096
Default RE: Jasper Transmission Band Adjustments?!
ANYONE??????
Old May 23, 2007 | 02:42 AM
master tech's Avatar
master tech
Site Moderator & Tech
I don't to sound dump, but what is a jasper trans???? You should have a 44RH or 46 RH 1990 thru 1994, 1995 up would be 44RE or 46RE unless you have diesel then it would be a 47RH or RE.
Old May 23, 2007 | 03:06 AM
padodgeram's Avatar
padodgeram
ORIGINAL: master tech
jasper transmission is a remanufactured...and if this guy is so worried they have a 36 MONTH/75,000 MILE WARRANTY .. take it back to who ever installed it and have them do the work cause if you temp to do this yourself , you mite void the warranty
Old May 28, 2007 | 06:11 PM
cam5096's Avatar
cam5096
I am out of the warranty period, that is why I asked for advice.
