truck will not move when put in gear
Old May 17, 2007 | 11:52 PM
shaneman18's Avatar
shaneman18
Default truck will not move when put in gear
i have a 1995 ram 1500 5.9 with auto trans.it will not go into gear. you put it in drive and it just sits there.what could be causing this?
Old May 18, 2007 | 12:45 AM
2big2dodge's Avatar
2big2dodge
Default RE: truck will not move when put in gear
only thing i could come up with is maybe the linkage fell off or something.
Old May 18, 2007 | 01:48 AM
hkspwrsche's Avatar
hkspwrsche
hope its not a bad trans
Old May 18, 2007 | 01:53 AM
jakebrake's Avatar
jakebrake
One easy thing to do is pull the inspection plate and make sure the tc is spinning with the engine. Some times those bolts break.
Old May 18, 2007 | 02:33 AM
982500Ram's Avatar
982500Ram
is the tranny really low on fluid? I have seen many vehicles do this when the fluid is very low or in very poor condition (burnt).
Old May 18, 2007 | 03:05 AM
master tech's Avatar
master tech
Site Moderator & Tech
Be sure the transfer box is 2hi or 4hi.
Old May 18, 2007 | 03:21 PM
Socha_62's Avatar
Socha_62
yeah, could be the t-case. or the linkage slipped or came off. Try to see if it'll move in R,N,2, or 1
Old Jun 12, 2013 | 10:52 AM
jones9023's Avatar
jones9023
Default 95 Ram won't move in gear
I have a 1995 5.9 with auto trans.it will not go into gear. you put it in drive and it just sits there. What could be causing this?
Pulled the pan and there was no major metal just a few shavings, put new filter and new fluid and it ran fine for a 30 minute drive and now nothing again
Please help!!!
Old Jun 12, 2013 | 11:00 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I'd say the tranny is toast. You could try adjusting the bands. Get a Haynes manual and see if you have the right tools to do so.
Old Jun 12, 2013 | 11:17 AM
jones9023's Avatar
jones9023
Got the Haynes manual. I surely hope it's not toast. The first time this happened there was no warning, no slipping, was going down interstate and it just stopped pulling. After it sat all night, it went in gear drove it 2 or 3 miles and then nothing.
Changed fluid and filter sat all night drove it 30 miles or more then started again.
