No 4x4
Old May 18, 2007 | 12:07 AM
Moparkid032's Avatar
Moparkid032
Default No 4x4
Ok well i got the truck up on the lift the other day at my school to see whats up with the 4 wheel drive..well the front driveshaft psins,but the u-joints in the front arent spinnig..so i am guessing the front axles arent engaging..now i came along this part while i was under my truck and my friend said this most likely is the cause..could anyone tell me then name of the part..and how hard it will be to replace?? thanks
[IMG]local://upfiles/62831/8C7A173B190E479F8131B2FC732C4509.jpg[/IMG]
Old May 18, 2007 | 12:11 AM
Socha_62's Avatar
Socha_62
Default RE: No 4x4
Its a vacuum problem, no need to replace the CAD unit. With a loss of vacuum the CAd can't function and doesn't engege the front end.
Trace all the vacuum lines and see where its broke. Just be careful, they're probably VERY fragile.
Old May 18, 2007 | 01:04 AM
Moparkid032
Default RE: No 4x4
so jus trace all the vaccum line from that part?? or should i look in other places to
Old May 18, 2007 | 01:39 AM
spaz_22's Avatar
spaz_22
Default RE: No 4x4
there is also vacuum lines on top of your tcase that you should check as well...the 2 vacuum lines run across your frame across the crossmember and to the top of your t case
Old May 18, 2007 | 02:26 AM
G0tMudd's Avatar
G0tMudd
Default RE: No 4x4
Happened to me, it passes right next to my cat *go figure* burnned right throught it. Just cut where it has been damaged and place some really tighting fitting hose, thats what i did.
Old May 18, 2007 | 03:11 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: No 4x4
If you are in 4wheel drive all the time, ck the vaccum hose next to the exhaust manifold on the driver side.The plastic tubing melts from the heat over time. So because you lost vaccum, the vaccum switch defaults to 4wheel drive.
Old May 20, 2007 | 04:44 PM
Moparkid032
Default RE: No 4x4
I forgot to mention that the 4x4 light wont come on either...could a vaccum issue cause this?
Old May 20, 2007 | 09:54 PM
flintspirit's Avatar
flintspirit
Default RE: No 4x4
Go to posi lock.com and buy a cable and throw the vacuum unit somewhere far far away! After replacing 2 of the vacuum units thats what I did and i've never had a problem since.As a side note if you install the cable then put a locker in the front you can gofull timeon the locker and just use the cable to engage both front tires!
Old May 20, 2007 | 10:59 PM
Moparkid032
Default RE: No 4x4
will it be hard to conver to the cable?
Old May 20, 2007 | 11:09 PM
flintspirit
Default RE: No 4x4
nope youll get the cable and a new housing to bolt right onto your axle .you will need to take the fork out of your old casing which is held in with c clips.I was very satisfied with mine and I know the front is locked.
